Parts and More Parts, mostly A body.
Mark Nixon
The Best Fun In The World Is Right There,
1967 Barracuda reverse lamp BEZALS (no lenses or lamp housings) some pitting, no corrosion, $30/pair.
1967-1969 Barracuda bumper jack, with tire iron, tire hold down bolt, cup and wing nut, $85.
1967 Barracuda, with air Air Conditioning, dash wiring harness, no cuts, no splices, no burn spots, $50.
(2) 1967 Barracuda window cranks, fair condition, $8 each.
1967 Barracuda FASTBACK trunklid, EXCELLENT rustfree, dentfree condition, no bubbling at the lip, no moldings or trim, $200.
1965-1972 A body 10" front brake drums, nice used condition replacements by Century Brake, $25 each or the pair for $40.
1965-1969 A body 10" rear brake drums, nice used condition, $25 each or both for $40.
1968 Dart grille in good condition, minor dents in 2 places, with decent lenses, includes mounting brackets and parklamp assemblies, $75.
1993-2002(?) 360 Magnum 11" flywheel, super hard to find, this is a REAL one, not rebalanced 318 one!! Mopar wants nearly $275 for a new one, I'll take $160.
1971 painted fender indicators, corrosion free and in working condition, $75/pair.
1970-73 B and E body 22 inch fan shroud, # 2998328, in EXCELLENT condition,with mounting brackets,$100.
1972-1976 A body painted gas cap, nice to restore, $20.
1963-'66 A body painted gas cap, $20.
Automatic console floor mounting brackets for A body, $30 for all 3.
1972 340 shortblock , dis-assembled, has a hole in the lower water jacket, which is an easy repair, as wells as a slight notch in one lower bore. Also has a steel STD crank and .020 over forged pistons, block will not need re-bored, $450.
1971 360, with 'J' heads, complete longblock with heads removed, # 3418496 cast block, needs bored .030 $275.
1972 360, with 'J' heads, ran when parked, but needs total rebuild, complete carb (2bbl) to pan, $350.
1969 'X heads, need valve job and have the typical cracks from the intake seats to the sparkplug hole, which never leak, no valves, NEVER rebuilt before, $225/pair.
1966-1972 C body oil pan, #187, often used for Big Block A body swaps, very minor dents, with pick-up screen, $75.
1977 400 longblock, from a pick-up, has '452 heads and truck oil pan. Ran when pulled 3 months ago, been sitting outside since and still turns over, $150.
1975 440, stuck tight, has '452 heads, will part out block, if there is an interest and it's savable, $50-up.
1965 413, ran when car was parked 5 years ago, complete air cleaner to oil pan, spins over freely as it sits, without tranny, $300.
1965 Big Block, slip yoke, cable shift transmission from above listing, was working fine when car was parked, very hard to find, 1 year only transmission, $200.
V-8 K member from '74 Duster, no cracks, no broken welds, no heavy bottoming out, $75.
A body pedal-to-Z-bar pushrod, Z bar and ballstuds, from a /6 car, modify for V-8, $60.
V-8 waybar and lower control arms, with tabs for swaybar, for '73-'76 A bodies, $125.
'73-'76 A body disc brake spindles, bare, $135 /pair.
'73-'76 A body upper control arms, $75/pair.
A body chrome sport mirrors, some pitting to the chrome, $165/pair.
Duster front and rear windshield trim, needs restored, $50/ front and rear set.
Complete '75 Duster sunroof assembly (whole roof), working condition, with some fixable rust issues, but very usable, $150.
Very nice black dashpad for '69-'76 A bodies, $135.
For inquiries, you may contact me via e-mail at Nixon340@yahoo.com, by phone at (402)-780-5127 or PM me here.
