thrashingcows
Well I bought a 68 dual snorkle air cleaner from a docker over on the c-body site I visit....Thanks again Charlie!!
So it had a few coats of paint on it after 40 years... :doh: ... and needed a clean up before I could repaint it. So I went down to my local jobber and bought a $10 can of spray on paint stripper. I followed the directions, rough up the painted surface with 80 grit paper then spray on and let sit 15 minutes or so then use scrapper to remove paint.
Well after the first application...not much happened...couple small spots lifted and that was it. So clean it off and proceed to do it again...this time...same damn thing.
Well now I'm a little cheesed since I used up almost 3/4 of the can and I have almost nothing to show for my $10 investment. So I get to thinking how I can strip this on the cheap....Hmmm brake fluid strips paint and is cheap.
So I set up some cardboard and put the aircleaner on a big wood block, grap the brake fluid and a paint brush and give it a good slathering.... after about 30 minutes I gave it another coating. Then I had to head out of town for work and when I got back last night after 3 days away and it was bubbling and pealing like crazy.
I took it outside and scrapped about 90% of the paint off with ease and then had to spend another hour or two getting into all the small tight spots with a small screwdriver.
So when all was said and done it looks great and I probably only used a dollar or two worth of brake fluid and got better resultas then the $10 can!!
