paint ?'s its 80deg i want to paint
69.5CUDA
Blah Blah Blah
few things to ask ..its been a while since i rushed to get all my supplys out of the shop befor the temp droped soooo there totaly un-organized
first off ive got some advantage 330 2k urethan primer ..ive got a bunch of activators but no clue wich actualy makes the stuff work
house of kolor kd2000 primer...can i run it over the ncp272
ppg dp90LF epoxy primer can i run it over the ncp272..EDIT acording to the spec sheet "topcoats" "dp epoxy primer LF"..i asume thats this stuff?
what can i safely mix into the ncp 272 as far as color goes? i asume only use urethanes
the top coat will be a home mix with the bulk of the mix being omni-AU mack truck silver
No. I was in the right place but I didn't understand a word you said and all I got out of it was your something hurts:lol:
Just had to zing ya one.....it's been a while[smilie=g:
It really kills the humor when you have to explain it, not my head hurts...:doh:.
True. Damn you 69.5 for not getting that one! :bwuhaha:
Ok I'll return the trhead back to the serious side of things.....as for the others....:shifty:
Nobody reccomends mix matching different brands of paint but sometimes its just the retailer wanting to get a sale. From my own experience martin stuff likes to react with ppg, clearcoats especially. As always try a small area first before wasting the whole thing.:hmmm:
well its not likely to be getting any clear unless i change my mind....everything listed above is primer or epoxy primer
