Paging Dr Jass..... 69.5 take a peek!
Key boards are now in my possession, 1st pick with the larger port connection seems to be more "clickety" then the second pick, 3rd pick is to show the different connectors? let me know if you want, I guess 2nd dibbs or even 2nd keyboard goes to 69.5? Rich.
shipping only , I'll just take the packaging charges for my troubles, should be able to keep that under 2 or 3K easy!:shifty: Rich.
First plug type is for the ancient ATX motherboards. The second plug type is the more common PS2 (no, not Play Station 2) motherboards. Both are going the way of the Do-Do since the advent of the standardized USB plug now being used for almost anything and everything that you can plug into a computer anymore.
Soooo, grab 'em while you can!
I've got some adapters that will convert the older, (larger) plug to the later PS2. ;)
I think gomo means AT motherboards, since I've never seen an ATX board that didn't have a PS2 connector... and I've seen a number of 'em.
I'll take 'em both, Rich... let me know through PM how much and where to send it.
ill wait and see what doc says but those dont look like old ibm clickys...edit never mind lol he poped in a split second befor i typed this
:hmmm: :doh: Good catch Doc. Mee thinks it's time to back off the meds just a little.:Fresh Meds:
