The number one plug on the motor is the front one on the driver's side. You should be able to chase that wire back to the distributor. If the wires are off the car, you'll have to find Top Dead Center on the #1 cylinder. You'll have to turn the motor until the piston in the #1 hole is at the very top, and pushing air out as it comes up. If it's not pushing air, it's not on the compression stroke, and the engine will be at TDC at a different piston. You can pull all the spark plugs before hand to make turning it easier. You can also pull the valve cover to make sure that the rockers on #1 are all the way up when the piston is at TDC. After you find TDC, check the timing mark on the crank pulley to make sure it's correct.. Should be at 0. Then, pull the cap off of the distributor to see which terminal the rotor is pointing at. That's number 1. The cylinders on the driver's side are odd, (1,3,5,7) and the cylinders on the passenger's side are 2,4,6,8 starting from the front. If this motor hasn't been started in years, I'd recommend changing the oil, and priming the oil pump and system first. That involves removing the distributor and the gear underneath, and cutting down a 5 gallon paint stirrer from Lowes and running it in a drill down the dizzy shaft. Then reassembling, and finding TDC on the distributor again. I'll provide more details on that if you need it. As for the motor numbers, there should be a date code, month and year stamped under one of the heads, but I'm sure somebody else will chime in with more accurate info
