Yeah, mine was an early '98. I'm not sure what you mean by air to air.
As for propane, I've never tried it. The thing about the nitrous is, it greatly lowers EGT's. Not AT ALL like a gas engine. The leaner you run it, the safer it is, as combustion temps come right on down as you lean it out. Of course, power suffers when it gets lean beyond a certain point. My pump is set up such that it delivers WAY too much fuel at low rpm and boost if you floor it. So, I just smack it, then spray it. The nitrous burns a lot of the extra fuel that would otherwise turn into smoke, and helps the turbo spool quickly. As the turbo spools up and supplies even more oxygen, the mixture gets leaner. Staying on the nitrous then helps cool the EGT's where they would otherwise be getting out of control. The bigger turbo I'm installing is gonna help with that even more, plus uncorking the exhaust a bunch. All this will make more power, plus I'll then be able to have it deliver even more fuel, making yet more power.
