Next thing I did was a complete front end rebuild. (rubber not poly)
Also swapped out lower control arms for ones that had the sway bar mounting tabs, and mounted up a bar from a 68 V-8 dart.
Handles much better with a fresh front end and a sway bar !
Heres a little pic
that should be way better,i am looking for the clamps for the swaybar bushings the dork that had it before me welded mine shut, but i think i got a line on one hopefully.papa-d
