b-body-bob
I changed the GTX from Green bearings back to factory tapered bearings this weekend. Don't let anyone tell you it's an easy job - unless you pay someone else to do it.
I had to remove 4 bearings - 2 were from JY axles I got for the end plates/adjuster. I couldn't come up with a safe way to jig them in my press so I had to cut them off with a hammer, chisel, and dremel tool. After all that beating and banging I'm totally stress free today. [smilie=a:
Putting the new bearings back on was a piece of cake since I was able to use my press going that direction.
Now that I've got them changed over, I don't understand the fascination with Green bearings. Setting the axle endplay was a no-brainer, and I should never have to change the bearings again.
Hopefully the roaring noise I was hearing left with the pieces of Green bearings I tossed in the trash.
