dodgedifferent2
ok i have been playing around with the dart alot as of late and today i went for a ride down the road:hmmm:
I had some fun
dumped the clutch a couple of times.
after the last time i noticed the oil pressure started to drop. It was running about half way on the gauge then dropped off to nothing and i shut her down.
I am hoping it is just a bad gauge. The sending unit is new
whats the best way to go? should i get a mechanical gauge and mount it in the hole?
Also i got a stock timing gear, if it was a high volume oil pump would the drive be wrong?
I knew i should have checked the damn oil pump while i was in the oil pan last time :doh:
I had some fun
