Lokar kickdown cable..
i'm using it and it works very well.... here is a pic of someones car with it....
Hey Vike, check out: www.magnumhp.com and take a look at the AR engineering adjustable throttle brackets. These are designed for use with the lockar kickdown cable setups.
Rob (kamstracuda) put one on his 408 stroker with the taller RPM airgap manifold and lockar setup and it fits great....maybe he'll post a pic of the setup....
Ron
Ps. These brackets are made for a mutitude of applications...smallblock, lowdeck (383-400) and raised deck (413-440) motors.
I have added the Lokar to my new tranny but haven't adjusted it yet.
Anyone have any tips??
if i can i will get a picture in the morning....
as far as adjusting it just put the throtle and kickdown leaver all the back and you should be good to go... you can fine tune it from there...
K - I made a change to your account. Try again.
I'll give it a shot with another pic.
I still get this
The Attachment is too big.
Max Size: -201326592 Bytes
b-body-bob said:
That's a negative number :)
Have you done the tried and true log out, clear cookies, log back in yet?
i hafta do that everytime i log into moparnuts....so i do it before i start browsing [smilie=b:
