Little tinkering on the RR.
beeper*71
This space for rent
Got my fan should made and installed......
Some trivia:
Anyone tell me what that shroud came out of? [smilie=e:
I had to modify it as it was to wide so I cut and sectioned it,also cut off the original mounting tabs.
My boss's dad just bought a plasma cutter and he allows me use it...man I need me one of those! [smilie=e:
Came in very handy for this job. [smilie=w:
Nice job modifing that, looks like it was made for it! [smilie=e: Rich.
Not even a guess as to where it came from???????? [smilie=e: Rich.
RUSTY Cuda said:
Not even a guess as to where it came from???????? [smilie=e: Rich.[/quote]
70's era Dodge truck.... [smilie=w:
It is 4 pieces spot welded together,I cut it apart at the welds and shortened the top and bottom parts then re-cut the radius in the 2 side pieces.Welded it back together,ground and smoothed (sound familiar Rusty?) made and welded on mounting tabs and paint.
Turned out pretty decent. [smilie=c:
Thats one piece I bought, the guy had a chromed(&rusted) home made metal thing on there, bolted right through the rad core!!!!!!! Now I just hope it fits with the different eng & fan on there???
Thats a nice piece a work, doesn't it feel good to make something like that, my stuff aint so perty but for under the sheet metal they will do! Rich.
roughrdr said:
All nice and shiny, except for the fan......What's up with that [smilie=e:[/quote]
[smilie=e: Yeah I know....I'm thinking that fan is too close to the radiator with the shroud installed anyhow. I need to order a single spacer the proper length and lose the mis-matched 2 piece set-up. At that time I will clean up the fan. [smilie=w:
Whats with the mis-matched coil wire?
I'll shut up now... [smilie=e:
Is that a BeCool rad?
If so, I need to know more about this little project of yours.
I have a BeCool going into the Charger and of course, I have no shroud for it..
What you've done looks great.
Not A Duster said:
But someone stole your battery
Funny thing that.......first time I slammed down the go pedal it wound up in the trunk! [smilie=2: :D
[size=2]musta forgot to fasten it down..[/size] [smilie=e:
