A
soap opera is an ongoing, episodic work of fiction, usually broadcast on
television or
radio. Programs described as soap operas have existed as an entertainment long enough for audiences to recognize them simply by the term
soap. The name
soap opera stems from the original dramatic
serials broadcast on radio that had
soap manufacturers such as
Procter and Gamble,
Colgate-Palmolive, and
Lever Brothers as the show's sponsors.
[1] These early radio serials were broadcast in weekday daytime slots when mostly housewives would be available to listen; thus the shows were aimed at and consumed by a predominantly female audience.
[1]
The term soap opera has at times been generally applied to any romantic serial,
[1] but is also used to describe the more naturalistic, unglamorous evening, prime-time drama serials of the
UK such as
Coronation Street.
[2] What differentiates a soap from other television drama programs is the open-ended nature of the narrative, with stories spanning several episodes. The defining feature that makes a program a soap opera is that it, according to Albert Moran, is "that form of television that works with a continuous open narrative. Each episode ends with a promise that the storyline is to be continued in another episode".
[3] Soap opera stories run concurrently, intersect, and lead into further developments. An individual episode of a soap opera will generally switch between several different concurrent story threads that may at times interconnect and affect one another, or may run entirely independent of each other. Each episode may feature some of the show's current storylines but not always all of them. There is some rotation of both storylines and actors so any given storyline or actor will appear in some but usually not all of a week's worth of episodes. Soap operas rarely "wrap things up" storywise, and generally avoid bringing all the current storylines to a conclusion at the same time. When one storyline ends there are always several other story threads at differing stages of development. Soap opera episodes typically end on some sort of
cliffhanger.
Evening soap operas sometimes differ from this general format and are more likely to feature the entire cast in each episode, and to represent all current storylines in each episode. Additionally, evening soap operas and other serials that run for only part of the year tend to bring things to a dramatic end-of-season cliffhanger.
In the
USA, the phrase "soap opera" has also entered the language as a metaphor that can be applied to any narrative, either real or imagined, that appears to be excessively laced with emotion, and contains what appear to be unlikely dramatic twists: "Her life is one big soap opera."
