it works!!!
69.5CUDA
Blah Blah Blah
well after MUCH ...hmm much isnt that much of a word...ALOT of soldering, cutting, shrink wrapping, 1 side of my turn signal assembly works...ive got about 3 hours in just the above mentioned "wiring" of 1 side....40 led's, 20 resistors, 60 1/2 strips of shrink wrap(still need to shrink the resistor sides)cutting of 20 jumper wires, cutting of 2 10pin leads for direction, 1 10 pin lead for feed with 2 plugs for direction changeing(not settled on what rotation directions i want on each side..the plugs let me change it to what i see fit)
..it was enuf to make my hand shake and my eyes go buggy...but it was worth it!!!!!!
have a look(btw if anyone knows why i cant import any music files into ulead videostudio let me know)
http://s2.photobucket.com/albums/y31/sh0rtlife/?action=view&current=taillighttest.flv
I would coordinate the direction of rotation with the turning of the steering wheel.
:2thumbs:
:2thumbs:
thats the plan.....im just not sure if i want the "gear" look with the bottom rotating backwards or if i want top and bottom rotating the same direction...
driver and passenger side are 100% seperate units and would only be on at the same time as "hazzards"
well another 3-4 hours into it..totaling out at 6-8 hours
80 led's
40 resistors
25 feet of 22g wire cut into 40 jumpers
10 feet of shrink wrap cut into very small pieces
2 project boxes
4 10post male and female bird connecters(think HD cable connectors only smaller)
1 old floppy cable for 6, 10 wire 6inch leads
im tired and bugeyed ....tested it all and both sides working flawlessly..and mounted into there boxes
tomarro i will install em on the car for a test veiwing and vid capture..as well as get some pic's
