68R/T said:Your car should have the flat blade-type clip like in the pic. The wire clip like they gave you will work fine as long as you're using OEM panels. If you've got repro panels you want to use the blade-type. The repro panels are thinner and the wires will cause a bulge in the panel at the clip locations.
