I Just Can't Help Myself....
68R/T
I got drunk and swallowed my teeth, now
Once a hot-rodder, always a hot-rodder
The 2bbl carb on my survivor 68 Coronet 4dr was leaking at the throttle shaft, sooooooooo.......
....as long as it's being changed...........
[smilie=e:
Gonna have a gas transport follow you around? Might not be too bad with some leeeeeeeeean az jets tho. [smilie=e:
giowest said:
2 450's?, 500's?.
625's :D
For normal driving it runs about the same as before, but when you stand on it there's this strange wooooooooaaaaaaaaahhhh noice that comes from under the hood. :D
With the 2bbl, the power would start falling off about 3k, now it's still pulls strong to about 55 in low.
[smilie=e: *[i]must have 2.76 gears[/i]
[smilie=e: No gear change, gonna try to keep it a hiway cruiser with a little flair. If'n I wanted another powerhouse it would've gotten more cubits.
68R/T said:
[smilie=e: No gear change, gonna try to keep it a hiway cruiser with a little flair. If'n I wanted another powerhouse it would've gotten more cubits.[/quote]
*stunned silence* our way of life has changed.......no more"I'd put a 440 in it!" [smilie=e:
73roadrunner said:
*stunned silence* our way of life has changed.......no more"I'd put a 440 in it!" [smilie=e:[/quote]
With those rear gears this thing will cruise at 80mph all day long on a quarter tank of gas.
I was getting about 21mpg with the 2bbl, if I stay out of it, [smilie=e: I might still get close to that. [smilie=e:
It's really quite surprising how much torque it has even in high gear.
It's really quite surprising how much torque it has even in high gear.[/quote]
j/k 68....that really is good looking car!What do you tach at 55mph....around 1500 rpm's? At least put some hood scoops on it! :D
Don't need a tach on a stock 318. [smilie=e:
Don't know what it turns for R's, maybe the good Doc will break out the formula and tell us what it turns with 25" tires. [smilie=e:
1/4 tank at 80 all day? [smilie=e: OK then we all better go out and purchase inline 2-4s if its the next thing for great gas mileage. [smilie=e: I will take a wild guess and say double nickles with a small 14 inch tire will get you about 2400 Rs. with 2.76s. 1250 cfm on a teen should be just right. [smilie=e:
