Robertson_Tech
- I checked the bucket nope not to full.
- I checked to see if the buckets got a hole in it. :looky:Nope
- I checked E bay to see if I was overduing it a little.
Maybe - So where did I all go today
- I got tired of looking for the correct parts to do a big bolt pattern front disk upgrade on the dart so I ordered parts with out asking here first I just went and ordered. What I hope is a good brake kit. Got the works for dart and stock stuff for the 66cuda. Anyone ever use Master Power this is the list.
- 11" vented cross-drilled/slotted rotors
- Calipers and pads
- Caliper brackets
- Master cylinder
- Spindles
- Combination valve kit
- Brake hoses
- Bearings/seals/dust caps
- Hardware
- Dust shields
- Upper A arms
- Upper and lower ball joints
- Control arms
- Control arm bushings
- I pointed out that my lower control arm would not work with later spindle and I was quoted that a new Lower Control Arm was included.
- I got the Graphite Poly rebuild kit as I have 45K on the last kit that was installed in the blue dart ( hard to beleve I put that many miles on it. )
- 71chagerR/T hooked me up with a source for a 65 only LA cable shift trans. I sent the check up but have not paid the 500 for shiping ( anyone know how I can ship a trans cheap? )
- The gasket Kit I got for the Volvo was not quite correct so I had to buy more gaskets
- I bought a mopar performance dist kit for the dart.
- Paid for a offy intake for the 71 dodge truck.
- I am paying someone to repair my house and he kicked ass on the kitchen and master bedroom today.
I wanted to go cheap on the brakes for the dart but then if I am building this as a show piece of what I can build for customers them I thought that would be bad. I want a solid platform as I hope to put a lot of wild motors in the dart for testing later.
Well I had fun and I hope you all did through me reading this and seeing pictures ( when I can get them done )
