hydrailic clutch engagement
383duster
they say I'm a sheep forker.......
got it today with the mail, just installed the master in the firewall, gotta fabricate something to mount the slave cilinder on the bellhousing, that's for tomorrow [smilie=a:
xlr8r said:
Just a thought, but you may want to reinforce the firewall,??
dunno, wil see what kind of force i gotta use to engage the clutch and if the firewall moves i will take a metal plate and will make the firewall stronger, hope i can see that tomorrow when i fabricate the rest
69.5CUDA said:
think i would reinforce it as well
every time i try to think everything goes wrong so i will see how it works, reinforcing is no problem though but if it's not nesessary (sp?) i won't do it, otherwise i will do it [smilie=w:
i can always ad reinforcement later that's no problem, and the master is mounted at more then 45* down so that wil put less force in the firewall, the brakemaster is mounted at 90* so the firewall will bulge easyer there.
if the firewall moves just a little i will put a thick plate behind it to spread the load, as i said it can be done easely later [smilie=w:
When ford first came out with the juice clutch setup on the diesel pickups they didnt reinforce the firewall and it was a big mistake.There was a TSB out within monthes and the next model year they were doubled up. [smilie=e:
Golly 383...perhaps you should reinforce the firewall. [smilie=a:
*Grabs club and begins beating dead horse.*
[smilie=eggface.gif]
I'm suprised no one has suggested firewall reinforcement... [smilie=e:
[img]http://wald.heim.at/urwald/541469/schnappschuesse/dead-horse.jpg[/img]
fork you all! [smilie=b: [smilie=w:
and the clutch kit is made for a late GM model! HA! [smilie=a:
*kicks dirt while getting reinforcing material* [smilie=e:
