Headers v. Manifolds
What would you run on your wife's semi-resto cruiser?
  • The cool, stock high-flow manifolds!
    Votes: 0 0.0%
  • The high-flow, efficient and lightweight aftermarket headers!
    Votes: 0 0.0%
  • Total voters
Not posted in Tech for a good reason. I know the benfits of headers, but this is a more complex thing than simple horsepower.
OK, here's my dilemma:
When I bought Lumpy's Runner, I knew many of the original parts were missing (cluster, dash & engine harnesses, exh. manifolds, etc.). Didn't bug me for the supreme entry-level price tag, and I figured I could be a little creative with wrong-year harnesses, etc. I also figured the correct HP exhaust manifolds weren't worth the expense for the drop in performance...
BUT...
Upon getting the car home, I found the original, correct HP manifolds, in stellar unrusted, unpitted shape lying in the back seat footwell. I was thrilled, both from the "I can use them" standpoint, as well as knowing I could easily recoup more than twice what I paid for the entire car on a perfect set of '72 HP manifolds alone.
The car will be a mild 400, or maybe a 451 (a 440 crank in a .035" 400 block). Either way, it will likely be a relatively-mild build. This is going to be a fun cruiser that we can drive to the Nats, not a crushing strip basher cranking out 11-second timeslips. It's really primarily Lump's car, and plans call for a 3.55 gear and a 4-speed to replace the factory 3-speed (I'll keep the numbers trans, no worries).
Being that the mill will be a mild build (not much more than a warmed 440), I tend to lean towards the manifolds, especially since I already have them... I don't believe headers will make a huge difference on this engine. But selling the manifolds could result in serious coin, that would more than offset the cost of a quality set of tubes, leaving precious leftover cash to gather parts.
I know the benefits of headers as well as anyone, but if it was your car, would you go for the cool, as-it-should-be manifold look (and the lack of header hassles & leaks), or would you go for the big guns and run the Hookers?
Even though it won't be running the original 400 ci & 3 spd, it will still retain original appearances, right?
I tend to agree with your first reasoning. I don't think that Lumpy will miss that slight loss of performance plus the shorter lifespan and clearance problems of headers.
A major part of the $'s made on the manifolds would go for the headers. $$$ - $$ = $ :D
Since youre not going for the 11 sec monster i would say stock manifolds, less hassle with heat,clearence, sound (i know that can be fun to but not on a 3 hour trip lol).
BUT if you feel that you really need some extra money sell em and get headers/ordinary manifolds for it.
Thats what i would do!
Me - I would get the car on the road using the parts that are on hand, spending the money on other, more neccesary things...
Then add the headers later if I felt I needed them.
It's also alway nice to have that stuff should you wanna change your mind later. I kept the manifolds, aircleaner, carb etc for mine & put them away should I ever return to stock (never happen) The intake was cracked, so it hit the dumpster...
I think you're right on track Jass... stick with the factory HP manifolds. Not only do they look pretty cool IMO, but you'll save that cashola for the wiring you need etc...
So, you want a replacement... just in case? I have a '73 340 intake sittin' on my work bench... :mrgreen:
Yeah, I do actually like the look of the HP manifolds m'self. 'Specially when they're Jet-Hot coated in cast-iron hue and stay pretty. And like I said, although headers are a huge gain on a go-to-hell hot-rod motor, I don't think the gain is very much on a mild big-block when compared to the high-flow castings.
Small-blocks, I think, are another can of worms entirely.
i like the air to flow in and outta a eng good...but Lumpy will be happy for now, and the head aches will be less with the manifolds..
Yeah, gotta agree, manifolds are the way for now. Unless the moon babies come back. Sorry. :roll:
I'm a big believer in the bb hi'performance manifolds. They flow enough for easy 12's and the Law doesn't mind them. :D
