340s like to be spun, and spun
high. No other Chrysler engine compares in that department by a long shot. It was the only small-block that had its own specific high-performance head casting (the X heads, and the J/O/U in '70).
All "J" heads have the 360 casting marks, even the 1970 castings. The 360 was already well on its way to production and with its larger displacement it needed larger ports than the crappy 273/318 heads. Since it was a newer casting, it got a different number and the "360" cast into it. They're not mid-'70s anything since the J casting disappeared at the end of the '72 model year (July '72), replaced by the miserable 587 casting (which was still far better than
any 273/318 head) Take 'em off the engine and I'll bet you $100 they've got the 2.02" valves.
Why does "everyone" love the X heads so much? Probably because X is a sexier letter than J and they're much harder to find. They're not worth the effort, since the Js are better,
period. Every competent Mopar specialty engine builder knows this. If they're 1.88" valves, all that needs to be done to make them superior to the X heads is cutting the intake seats and installing the 2.02" intake valves. I've never had a set of Js with cracked valve seats, but I've only had six sets of factory 2.02" heads and a dozen or better sets of 1.88" (I still have five sets of those).
There is no "improved" version of the SP2P (dual-plane) or the Streetmaster (single plane) intakes. Those are total pieces of shit designed solely for fuel economy, and they didn't even do that well. Why you would think either has any redeeming qualities whatsoever is beyond me unless you're hell-bent on going slow. They make less power than a 360-2V intake, for fuck's sake. Those piles of scrap aluminum came long
after the LD4B. The LD4B was an NHRA-approved 4-barrel intake for 273/318 engines, which is why it has a late-60s style Mopar casting number on it as well as the Edelbrock part number. It's an old DC intake, and because of that guys not truly interested in making power or stuck in the '60s seek them out and often pay idiotic money for them (the same guys stuck on X heads, maybe?). On the dyno, it's about the equal of the factory '71-up spread-bore (ThermoQuad) intake but it's a bunch lighter. It's not as awful as the Performer 2176 and
nothing is as bad as either the SP2P or Streetmaster. The LD4B is simply a small-port version of the legendary LD340--which guys will still club each other over the head to get for some reason. The LD340 was the best dual-plane intake for the LA engine for probably 25 years, but time and technology left it behind. If you want to run a dual-plane, the only game in town is really the Edelbrock Performer RPM, with or without the Air Gap (preferably with). It's actually much better than even some single planes, such as the Torker/Torker II and Holley Street (not
Strip) Dominator.
If you don't want to spend much money on it, keep the LD4B. It's a decent intake and you've already got it. You could also sell it on eBay and potentially make good money on it if it was bead-blasted and new-looking. Use the money to pick up a swap-meet/eBay/Craigslist Performer RPM, Victor Jr., or Strip Dominator. The Performer RPM will still maintain what torque is there, but with either of the single-plane designs don't plan on shifting below 6,500RPM.
Here's a good illustration, by the way, of what makes the SP2P such a pile of shit. Note that the same idiotic port sizes, with an extremely-small, choked-out plenum was used on the even-worse Streetmaster.
