Yes, unless you've got the front suspension down and are bringing it up from the bottom... and even then, it's dicey. With your nice paint job, I wouldn't risk it.giowest said:Any of you that have swapped 68-70 B cars engines know if the hood does have to come off fore sure?.
Dr.Jass said:Yes, unless you've got the front suspension down and are bringing it up from the bottom... and even then, it's dicey. With your nice paint job, I wouldn't risk it.giowest said:Any of you that have swapped 68-70 B cars engines know if the hood does have to come off fore sure?.
Get one of your pushin' neighbors to help you take the hood off... you'll save a ton of headaches... get an old blanket to put on the floor, and whatever you do, don't rest it on the rear corners. Set it on its side and lean it against the wall.
68R/T said:To some people it may sound like more work, but I've always preferred to drop the engine in without the trans. (especially if you don't want to scratch up your new paint on the firewall)
But yours is only green, so, "what the he11"![]()
