Anyone ever really mess with this program?
I've been having a lot of fun with it lately... I know some folks say it's not accurate, it's overly optimistic, etc. but I ran Car Craft's old W2 Stroker engine build and came within 2HP of their actual dyno run peak HP. The graphs were quite close, too, so I think it's a matter of being very susceptible to GIGO (garbage in, garbage out).
Well, one aspect of the program I hadn't messed with previously was the Iterator--now that is a cool thing with which to play... you can put in a range of camshaft specs, compression ratios, even bore/stroke combinations on your current engine, and it will pick out the best combination(s)--up to 10--based on whether you want max HP or max torque. Obviously, the more variables you choose, the longer it's going to take to work out every possible combo... but if you have a fast PC it's not so bad (it'll warn you when you get ridiculous).
Anyhow, I ran my 318 through it using realistic head-flow numbers from ported "J" castings (actual flow numbers, though not from mine), the 276/.490" solid MP cam I'm running, and a TQ atop a single-plane intake, with 9.2:1 compression... I think I need a better crank.
I didn't do any iterations on it, other than what would happen with 1.6:1 rockers (not a hell of a lot, actually) but this is my combo as it stands.
Even if it's off by 10-15%, it's still a relatively-stout pump-gas grocery motor... for aboot $1700. [smilie=e:
