Dynoed the '09 hemi truck today
v8440
Ok, I have some results at the wheels. Our local dyno said mine made 307/313. This dyno is FAMOUSLY conservative, to the point that cars with known weight could not POSSIBLY run the trap speeds they do making as little hp as this dyno says they make. Prime example: my mustang trapped 137 mph with the 393 ford that was in it. It weighed 3200 lbs with me in the car. The dyno I put my truck on today said the mustang made 546 hp.
Also, I could not dyno the truck in direct drive, which would be 3rd gear in our transmissions, because it hit the damn speed limiter! It took me a pull or two to realize that. Running it in a lower gear generally hurts results at least a little.
So, take my results with a grain of salt, as most other people would likely see higher numbers on other dynos.
