Design your own gauges!
You can do it here. Just the ticket for that custom cluster of which you've been dreaming.
Pretty cool site once you mess around with it for a little while... they have tons of options to customize the gauge faces to your tastes. You can even upload a logo or custom text and position as desired. Messing around with the customization can be rather addicting. The gauges are different price ranges, with the "Speedhut" line being the least expensive. Certain gauges are not available in certain lines, but since you can customize each gaugem you can make them look identical, i.e. a Speedhut tachometer with a Legacy- or Revolution-series boost gauge can be made to look identical. They even have reverse-rotation speedometers, a la original Shelby Cobra. They're not cheap, but for an Autometer with equivalent features (such as through-the-dial LED lighting, stepper-motor needles, etc.) you'll pay much more. A multi-gauge order generates an automatic discount, too. The GPS speedometers are really cool, and a freakin' bargain compared to other brands.
Best of all? U.S.A. made with lifetime warranty on the gauge itself, and a 5-year warranty on the senders! They don't do mechanical gauges for you old-schoolers that think those are more accurate (they're not). Electrical gauges are good enough for a commercial aircraft, so they're good enough for me.
i STILL want a 2-3inch speedo and tach....i want the FULL set of guages ALL the same size...the tach ive found a couple times..but are scarce....speedos dont seem to exist in "small"
I guess you didn't spend any time at that site, since they offer at least 36 different options in 2-1/16" and 2-5/8" sizes, from 20MPH all the way to 200MPH. That's not including the KPH models that are available as well... all with changeable fonts, pointers, bezels, colors, etc.
Look in the Legacy and Revolution lines. Don't use the filters on the LH side of the screen until you're into the gauge line (Legacy or Revolution) page. Try this one:
http://www.speedhut.com/gauges/Speedometers-Standard-Legacy-Gauges-Only/36:2|1:4|38:1|39:1/i=12&p=6 which is page 6 of the Legacy speedometers with the filters "Speedometers", "Standard" (eliminates the Metric options), and "Gauges Only" chosen. Page 7 linked at the bottom, and is all small speedometers, too. Going into the "Revolution" line, the last two pages (also 6 & 7) are the same way with those filters. All of their speedometers are programmable, meaning you'll need a sender of some kind, but they can be made to work with just about anything you can squeeze into your trans, and probably even "flying magnets" on the driveshaft. The GPS units, which measure speed via satellite, don't require a sender but they're not available in the small size (yet, anyhow).
Once you click on the gauge of your choice, you can customize from there: fonts, face colors, needle styles, bezels, etc.
2-1/16" 200MPH speedo. Customization options on the left size of the screen: http://www.speedhut.com/gauge/GR2-SPEEDO-06/7/Speedometer-Gauge-200mph-programmable
