71ChargerRT
I found and picked up a pair of M715 headlight housings, buckets and trim rings. I also found the radiator just sitting in place, held in by free will, radiator hoses and trans cooling lines. I yanked it to see it it was fixable, but no, no such luck. So while I had it out I removed the A/C and hideous grille, and I found a piece of stretched steel lying around so I cut it and fit it in. I also popped in the headlight housings, no lights yet, I have to mod the housings a bit and repair the headlight harness. I installed true Jeep hood hold downs, and hood pins because the others were a little loose for my taste. I am debating on using the factory turn signals or getting some round LED style to put in next to the headlights. I thought about driving/fog lights in there, but the brush guard upright is just about dead center of the hole. While doing all that I decided to remove the tail lights, 2 different years, and I modified the housings and I'm going to use the LED tail lights I bought for my truck in there instead, post pics of that later. Pics of the front...
