Cone-type Sure Grip guts
I need various internal parts for cone-type Sure Grip diffs, including but not limited to springs, spring plates, spider gears and spider-gear washers. If you have an old one with a shot spider pin and/or ovalled pin bore, I'll take the whole thing off your hands for the guts.
PM me if you have anything I can use.
Open diff washers will work with a slight bit of trimming.
I have several sets of the gears, both small and large, but you MUST take the shafts with the smaller ones, no, really, they are welded to the shaft, ala friction.
I've saved them before.
I may also have the springs and plates, but I still have one carrier to assemble, myself, so I get first picks.[smilie=e:
Though SLIGHTLY larger, I've used open diff spider shafts in the cone style surgrips with no ill affects.
Mark.
