CNC Max Wedge Victor head pics.....
snook
Jeff at Modern Cylinder Head ran his CNC program on my MW Victor heads, I believe this is the first set he's done. They came out awesome; the difference after the CNC port is obvious, these dudes will move some air. Well worth the $$$.
The heads will be dropped off at Treasure Coast machine for a valve job and clean up work. I'll post some before/after pics, see here:
Before:
After:
Before:
After:
WOW what a difference...is that the finshed surface of will they get a final "smoothing" finish??
I'm not that savy on porting so....:huh:
:bravo: did you get to keep all the aluminum that was removed ? there had to be a ton .
looks good :bravo:
I'm telling you, I could feel the weight difference when I picked the head up out of the box. Each head had to be about 4-5 pounds lighter, + or -.
