I know I'm not supposed to post but this is from the Clarion website:
How do I set the clock? There are several ways of setting the clock, depending on the model number.
Method 1 Press and hold BAND and DISP to display the clock. Press and hold BAND and DISP until the display flashes. SEARCH left to adjust the hours; right to adjust the minutes. Press BAND to set.
Method 2 Same as method 1 except press DISP to set.
Method 3 Press ADJ. SEARCH left or right to select clock and press ENT. SEARCH left or right to select the hour or minute. Turn rotary knob clockwise or counterclockwise to set the correct time. Press ENT to store time. Press ADJ to return to the previous mode.
Method 4 Press and hold BAND and FUNCTION to display clock. Press and hold BAND and FUNCTION until the display flashes. SEARCH left to adjust hours; right to adjust minutes. Press BAND to store.
Method 5 While the display is showing the clock, press and hold the CLOCK button until the minutes flash. Press the CLOCK button to adjust the minutes. When the CLOCK button is released for 5 seconds the hours will flash. Press the CLOCK button to adjust the hours. When the CLOCK button is released for 5 seconds the time will be set.
