Diplomat_Wagon
Hiding In The Bushes While
Can you use any stainless steel whip for a CB?
get it working then tape your flourescent black light bulb to it and key up the mic. [smilie=2:[/quote]
:wtf:
I kinda figured, I guess I could get away with a grounded AM/FM antenna.
......I think it has more to do with length or something. SWR meters and crap.
SWR - Standing Wave Ratio
DO NOT key the mic until you've had the antenna metered in.:naughty:
You could blow the CB......don't ask me how I know this.:doh:
102" is idealA straight whip would need to be pretty long to give the best performance.
102" is the ideal length for a 1/4 wave antenna.
Most mobile CB antennas have a coil to make up the difference between the length of the whip and 102"
This is an okay explanation:
http://signalengineering.com/ultimate/mobile_antennas.html
I still have my modified Cobra 2000GTL it has over 350 channels, and sports a D-104 loli-pop.I also run for a mobile, a Galaxy Pluto export unit with the same channels and a D-104m. My next investment will be a Wilson 2000 antenna. When I had the base running it was hooked to a Boomer-250 ( for a little extra kick) and an Antron-99 fiberglass antenna. It was good for about a 40 mile range, and some serious skip talk.Yes. I used to have a base station in my bedroom when I was a kid.. :dcf:
So I would have to get a wrapped antenna that has the equivelent length of 102"?
hey Dippy-- how much do you want to spend and how far do you want to go...????as in how far do you want to get out? out there on the prairies you could skip right into BC with no trouble at all and hit ONT with a real good set up. just like you were next door:bwuhaha::bwuhaha::bwuhaha:-- your nice and flat out there. a little trouble over the mountains but you can do it..if you got the power you could hit the islands inthe south... if i lived on the prairies i would put up a system put it all on a rotor dial in and hit it.. you could punch out every tv set for a mile:bwuhaha:now thats fun. and they don,t know where it,s comin from. your neibours would get pissed but get them involved and you wont have a problem:bwuhahar put up a fence:bwuhaha:i shouldn,t start thinkin about this stuff. i might have to build one to cut the craving:bwuhaha:---- I,M A BAAAAAAD BOY:bwuhaha::bwuhaha:
Ok, 102" it a little long for what I want.
I have two nice balls that I would like to use if possible.
Will probably be using one.
How about these put onto my balls?
Would these work as a pair?
