9379S = 1983 truck 360 carb; the wire on the back is for a bowl-vent solenoid. It's an 800s, but it's probably a tad lean for your 360, Geo... OK, probably a bunch lean.
One thing to remember, too, about ThermoQuads: if there's no small hose nipple to the right of the right idle-mixture screw as you look at the front, it has no ported vacuum as needed for vacuum advance distributors. That 9379S should have one, being a truck carb, but no guarantees.
If I were you, I'd go with the 440 carb; the jetting is probably OK for your engine on that one.
