cant "cow" tip this one..or can you?
69.5CUDA
Blah Blah Blah
got a late night "moo" in the dark..a big noisy thing rumbled into the hood..good god youd think the driver was deaf after hearing the truck...
something long sleek and black slid off the trailer out rumbled the 58 ford and in she slid...me and fishy did a lil looking over then i wandered off into the shadows hopped in my ford and creeped back into the driveway fired her up only after i couldnt coast any further and hit the headlights..all 4..fishy felt like the fat kid on christine with her blue ovil sister stairing him down pined up against this face
cows new toy ar8ived..me and fish will be going over it and tossing around ideas and snappin a ton of pic's.....1 look at the flatty under the hood begs the question..would it run if i fed it some fuel......and what would it sound like
so me and fishy have started going over it and its quirky and cool with some really STRANGE stuff
dual heaters 1 driver 1 passenger....dual zone climate control...
clear plexi knobs on EVERYTHING
the coolest horn ring..EVER
...someone had a twisted mind on the hood orniment..tits..and its realy the only thing to grab to lift the hood initialy.....
oddly "wrapped" leaf springs???
a 3link rear with leafs?!?!?
sinlge steering arm NO center link....just 2 rods off the box
stuffing a V8 in one would be HELL!!!!!! clearances and such..imo the only good replacement motor would be a ford 6 or a slanty stood up...if one didnt run the stock stuff
the car screams for a set of wide whites...
glass lenses on everything
virtualy no rust..were talking a few dime size spots in the floor and thats IT
it doesnt have a back seat..its a couch with room to sleep on the floor
the rear side windows...i would be forced to cut on this car..they only go half way down due to that massive oversides wheel well...id make a box and set it up to go all the way down or use a setup from a 57-9 ford and have the back corner piviot
the front windows are a TRIP..no wing window post....and locking wing windows
ill be grabbin pics tommaro with a clear head..its been a long week allready
so its a cross between my strange ford 3spd od and an automatic..and i thought my od was a strange one
Wraped leaf springs were common. If you look there probably are grease zerks on them as well.
What's strange about them? :huh:
I grew up with O.D.'s and fluids all around. Drove a lot of the O.D.'s.
We used to connect a toggle switch to the throttle kick-down switch, so we could kick it in and out when we wanted. In normal opperation, if you were in OD and hit the gas, it would drop down to the normal gear. we would wind it out in a gear, back off the gas 'til the OD hit, flip the switch, then floor it in OD. It was like driving a 6 spd, but only clutching twice. :giggedy:
The fluids are total slop. :dgt: They're like driving a car with an oil-soaked clutch. You can't break the tire loose on wet leaves, no matter what you do. :doh:
Just got home, been out of town for work for a few days.
Big...Thank you!!! To 69 and Fishy for allowing me to have Fernando dropped off. I appreciate it guys!! Can't wait to get down to pick up the car, and have a meet and greet.
Keep the idea's a flowing....;)
Well the motor won't run....look at it from the underside and you'll see why.....no oil pan, pistons or rods!! I have a complete rebuilt and running flat 6 and "Manual" 3spd that will be going in when time allows. Yeah those Fluid drive trannies are also know as slush box's....:D
I was under the impression the rear windows went all the way down, maybe it just needs a little love and lube to get things working again. If not your idea about using the 57-59 ford rear pivot point and then have the front side drop down would be a great idea!!
Wheels I'm thinking wide whites as well, with fresh painted black rims and the stock caps, or a nice set of stainless full wheel covers I have from a 56 Chrysler.
after sticking my hand a half mile up the rear wheel wells..im 99% positive the rear windows bottom out on the wheel wells
as far as mods go theres very very little id do to it..
i HATE the door locks...there NOT smooth and they dont flow with the car at all..id run something from the 50's if possible..even the ones from my 58 ford if they wernt weak ..one look at them and you will see what i mean
see about stuffing the bumpers a little bit...it would clean up the lines and "un-bumper car" it quite a bit
disc brakes and or atleast an updated "dual" chamber master cyl
the BIG one to me is the fill cap....its in a shitty location body wise...it just hangs out there saying look at how out of place and un refind i am...even moving it into the trunk would be an improvement LOL
as far as work goes.
it doesnt need floors..it just needs very very minor patching..to be honest it just needs rust proofing ...the floors are so solid that i hate to say it but id rust proof it and likely use a lil seam sealer on the holes..its really that minor...unless you find more whire wheeling prepping to rust proof....
new seals thru-out tho the door seals are actualy still sealing it oddly enuf...the welting is the same stuff used on my 58 ford..and the whisker seals look to be very similar to my ford as well..have a look at mac's for stuff
outside of the passenger fender the body is almost flawlessly straight..theres 1 small dent in the rear fender that could likely be pounded out with my hand er fist
youve got the motor and trans covered
needs a couple peices of glass but its all flat EXCEPT the rear window
the trim needs polishing but i dont see any dings or scratches..infact the bumpers and grill look briliant
im not sure what your doing with the wireing and the i can only asume 6v system...if it is 6v and your leaving it that way(which i would unless you replace all the CLOTH wireing)ive got some links and tricks to getting the lights or atleast the headlights brighter..even running the stock genny....personaly i like the older feel tho with the headlights dimming down at idle due to the genny
wide whites are a must imo..but you may want to go wider as wider is actualy a little cheeper from the digging ive been doing on the subject but to go wider your going to have to figure out some back spacing ..plenty of room BEHIND the wheels but the body to wheel face not so much
alot of the interior plaxi knobs are either trashed or broken..those intact look beat but rubbing your fingers over them brings them back to life
brake lines and fuel lines.."maybe"..youd actualy be suprised..i know 10 year differance but the lines on my 58 look as good as the day the car was made..and this soto looks to be in about the same or better condition
a re-spray and rust proof is in order
interior..its hammered
thats basicaly it.....i dont see anything out of place or wrong with it anywhere...its in flat out AMAZING condition...id likely inspect the brakes dial em in drop your tank check it out then put your motor/trans in it a seat cover and enjoy it for the rest of the summer
EARLY HEMI! HOT HEADS PARTS AND 8 STROMBERGS! Thats all I'm going to say. :D
Cow, this thing is cool! I don't blame you for one second for buying it! I sure as hell would have! Cool stuff for sure!
Well 69 as usual we think both seem to think along the same lines.:)
I appreciate your assessment of the car 69. The seller was very open and forth coming about the car, and I was quite comfortable buying it site unseen. But it's always nice to hear that there was no hidden issues.
I have new rubber brake lines, and wheel cylinder, and master cylinder, rebuild kits. I might not get the wide whites on it right away since I have to get it through Gov't inspection first before I can register it, so cash will have to be spent on that first.
I can get all new glass, everything except the rear glass, for about $500, I talked to a local shop and they can't cut me glass for that price. This company specializes in vintage flat glass for all makes and models.
Since the Desoto, Chrysler and Dodge of this era are all basically the same car, and their little brother the Plymouth, there is a surprising amount of parts available for these cars. And since they are not overly popular you can still get a lot of NOS pieces for decent prices.
These 2dr sedans were rare to start with, and I had a time finding any decent ones for sale. When the seller contacted me with this car, and I saw the pics and got the info, I knew from the start that it was the "one".
Hey Thanks Stretchy!!
Well I have a 331 Hemi in the garage, but I'm not sure I want to go that route now. The early Hemi is cool, but it's almost expected now days. I'm seriously considering leaving it a flat head 6, you just don't see them and they are a bullet proof, and relatively simple motor. Plus it's leaves the car a little more "stock". I can do some period correct mods, dual carbs, and split exhaust manifold, and maybe even an aluminum head. I plan on running the rebuilt 236 flattie I picked up, but the original motor is a bigger 251cu.in, and I hope to build it up to 265.
you couldnt even ask me to drop a hemi into it...the modifications just to make it fit would be HELL.........and then to make everything work once in there..a bloody nightnamre in itsellf...the steering stuff tells you to goto hell as is...the wheel wells are to narrow to fit it....im not against cutting and modding to fit but the hemi would be a silly route in this body..me and fishy talked it over and if someone wanted bad enuf..the best swaps would all be inline 6's.......hell a supra 6 would fit in there WITH twin hair dryers better than ANY v8 ever made
let me know where you end up getting wide whites from cow...im starting to eyeball some lesser known brands on ebay just cause of the cost savings gets about 100$ a tire LESS
