What I'm really trying to find out is which way it should be hooked up. The tube will lase either way, but I'm not sure which end is supposed to be the cathode and which should be the anode. If you get it backwards and run it for long, the (incorrect) cathode will overheat and deposit material onto the mirror at that end of the tube, ruining the laser. I've read that the current draw of the tube will differ between being hooked up correctly or not, but I don't know whether it will draw more or less when hooked up correctly. My power supply has a milliammeter built in, so if someone can tell me for sure about that then I can find out which way it should be.
*Edit* I noticed that one end of the tube has a coil of tubing inside for the coolant to go through, but the other end does not. That tells me the designers expected the end with the coil to be producing more heat, and they put the coil of coolant tubing in there to dissipate it. I also know that the cathode should produce more heat. If my reasoning is right, I had it hooked up correctly when I was setting the paper on fire and burning holes in the shop rag yesterday.
