Calling all junkyard warriors!!!!!!!
wontgetdusted
Ok guys and gals... I have recently came into a 1980 Dodge D-50 sport in pretty good shape with a 2.6l and a 5speed. However I'm waiting for the day the 4cyl pops and then the 360 swap will occur..but I will need those of you who hit the yards time to time to keep a eye out for something i need to find please ... a lsd or posi unit (gears dont matter)from the following
older 4cyl montero or raider 2 or 4wd
4cyl 4wd mighty max or d50 truck
I also need to find a set of block hugger headers for a small block if any has any lying around....
Also has anybody seen a small block mopar full front sump oil pan? I know they stuck some odd ball stuff in buses and motorhomes but i never paid alot of attention....
Thanks!
Not A Duster had a set of block-huggers but I think he sold them.
Unless I'm mistaken, the oil pan and pickup you seek is pretty common: 1971-92 B150 van; probably the same for the Magnums until the bitter end. It seems to this addled mind that at one point I had a front-sump pan for a B/RB engine and it was a van part.
Hey, I might have what you need. I work at a junkyard called pull-a-part. We have some mitsubishi stuff out there, and a d50 or two. You'll just have to come out and check. Also, I have a set of headers to put a smallblock in a datsun z. They're not exactly block huggers but they're close. You could maybe get an exhaust shop to cut them and weld collector flanges on them.
Thanks!
v8440,
Why do you post stuff like this? :bwuhaha: Your a re-re! Hey when you get off work from pull-a-part across town from my house why dont you stop by. We are having a barbque and i'd love for you to come by so i can answer the door then slam it in YO FACE!
Ok, biznitch! Then I can back my 2009 hemi truck up in your front yard and launch some of your grass into the 5th dimension! Oh, and I need to borrow your bathroom for the meximeltdown I'm gonna have. I'll smooth stop drop and roll.
(Hey, what's that sound? It's the sound of a chalupa hitting the water at mach 3!)
