Robertson_Tech
I think I am leaning toward this setup
http://www.flowperformance.com/
I was thinking about this
http://www.performancetrends.com/ez_flow_system.htm
But to be accurate with a orifice from what I have read about flow benches, combined with my 22 years measuring gas flow and pressure on semiconductor equipment you need to change the orfice when you change ranges.
I also found one of thies on e-bay but it is the 2.0" and that would not handle enough flow. see www.audietech.com
For vacuum pumps I was thinking about starting with 6 2 stage pumps that flow over 100 CFM so the flow should not drop off as fast @ 28"water I will build it to hold 8
Anyone here use a flowbench? I have ported heads w/o using templets but I want to move up a notch
