Recently unearthed in North Richland Hills, Texas, this newly-discovered relic predates all previously-known examples. It's uncovering during excavation of an ancient Mayan-civilzation earthen mound has earned it the "BermoQuad". The significant amount of sand found inside it has been tested and is consistent with the sedimentary stone used in construction of the Great Pyramid at Giza, further deepening the mystery.
The rare, ancient mechanism has been sent to noted carbologist Dr. Hugh Jass, BS, MS, PhD* for additional analysis. While not certain, upon initial disassembly he feels that with modern science and methodology he may be able to revive this fossil so that it may roam the Earth again. However, he is quick to caution that, due to extensive corrosion, nothing is guaranteed. Further disassembly has been delayed until it has been thoroughly soaked in a mildly-caustic solution, a process he says will take quite some time, probably "until 7PM Tuesday of next year." He added, "'BermoQuad' my pastey-white well-fed ass. More like TetanoQuad. I'm glad my shots are up to date."
Seriously, 71ChargerR/T... where the hell did you dig this thing up?! Wow!
Yes, that's moisture in the center-right cavity. It might have been fuel at one point, but I think it's Homer Formby's Furniture Refinisher now. Worst varnish smell I've experienced to date. There was enough in it to spill out when I split the carb.
Some people don't like ThermoQuads, but the beaches are fantastic! :dance:
The sediment from the float bowls, poured onto an otherwise-clean surface (all the dirt is from the bowls) with an ignition key for scale :doh: :
I did not pile it up. That's literally how it poured out.
*BS, MS, PhD = BullShit, More of Same, Piled higher and Deeper
