74DartSport
has asparagus pee
OK, got a fireplace in my basement that's not used. The opening has been covered with an ⅛" steel plate. I'd like to put a woodstove in the basement just to help warm that end of the house up a little. Can I just lift out the damper door, and cut a hole in the plate for the flue pipe from the stove; or do I have to make sure the flue pipe turns up inside the hearth and up past where the damper was?
