I'm breaking the motor/trans apart right now. I loctited the bolts last season and now found three of the four bolts had worked loose. So make sure you check those bolts, even after loctiting, periodically. Could have been bad.
snook i check mine every other race & often found them loose. the first time they came loose i heard a h3ll of a rattle when i shut off the car. when i found the problem the 4 TC bolts were hanging on by only a thread.
this year i had CUDA at an alignment shop. the guy called & said "greg you got a problem" 1 of the flex plate flanges broke & was hanging down. R & R the tranny, a new flex plate & we won the next reace.
