MoparNutt
STARTING OVER
I finally have all my parts to do my exhaust system.........
Ceramic coat headers from Summit....check
2.5" Flowmaster 40 series muffs....check
2.5" electronic cutouts from QTP....check
Couple lengths of 2.5" polished stainless pipe....check
The fun started last weekend. I had no idea how much bs it was going to be to changer from power to manual steering, but I managed to get it done. Then the headers went on without too much cussing. However, doing the pass side was fun........ Drained the oil, then slid the bucket over under the filter. Removed the filter so I could get the header up in there, but its on a 90 degree adapter....:doh:... I cleaned off the filter and put it aside. As I'm reaching up loosening the bolt, the adapter drops right into the bucket of oil, soaking the floor, my shoulder, the tire.......
I get around the front of the car to clean up the mess and soon as I grab the bucket..... swoosh, it was cracked in half. The oil spread everywhere. [smilie=f:So I run across town to NAPA to get a bag of floor dry. My buddy was working so had to shoot the breeze for 20min. By the time I got back home the 4 ft oil spot had spread out to about a 12ft spill. After 2 hrs of down time for a clean up it took about 20 min to put the header on, install a filter & new oil and drop her down.
So I fire it up to back into the shop. I notice the fans not moving. :hmmm: I guess I overlooked that part. Once the power steering was out I had nothing running the fan and water pump. I was searching all over in my parts for a double pulley so I could run it off the A/C belt, no luck...........
After leaving it alone for a couple days I got to thinking about it while I was working today and thought maybe the other single pulleys I have could be a different offset. Soon as I got home I grabbed one out and sure enough, it was what I needed. When I tried to put it on, its bigger so it was hitting the crank pulley. Back to digging in boxes again and in a few minutes came up with the matching crank pulley to go with it.
She's back togeather again but no belt on the A/C. I figured I will leave that issue til later, as long as the fans working I'm good to go. So now I have to get some cutting and bending done then the exhaust will be going on.........
I will post some pics of the before and after once the work is done
