dodge340dart
Active member
more pictures at this link http://www.picturetrail.com/mdart70
70 dodge dart swinger,originally a 340/4 speed car. 340 bored .040, trw flat top pistons,full floating, new bushings,steel crank, J heads milled and ported,11.0 compression,crane roller rockers,new springs,guides,seats,2.02/1.6 stainless valves,victor jr intake matched to heads,750 demon carb,.555 solid lift comp cam,msd distributor,msd 6A box,CSI water pump,(2) holley electric fuel pumps,1/2 BRAIDED FUEL LINES,aftermarket wiring harness,all together and fused,BE COOL aluminum radiator,electric fan,sheet metal aluminum valve covers,jet coated headers,400hp NOS,2 fuel regulators/gauges,904 trans, low 1st gear,reverse/manual Turbo Action valve body,Turbo Action 8 in 5500 stall converter,Dennys Driveshaft,shortened 8 3/4 rear, new 489 center section with new spool and new 4.57 gears,shortened axles,3 1/2 centerlines on front , and on rear a set of m/t street ets,mini tubbed,8 pt cage,20 gal aluminum fuel cell with sender,billet tilt steering column,racing seats.
the motor is together and has 2 hrs running time on it, Mike Janis (pro-mod champ------widowmaker) did the machine work. Its now painted base clear metallic silver with some of the castings smoothed, the intake is polished as is the valve covers and steering box ,the firewall and innerfenders were removed ,and replaced with sheet steel for a "cleaner"under hood look. all wiring etc(brake lines,line lock etc) mounted underneat the fenderwells so you cant see them, the fenders were cut and modified where they now bolt from underneath as well, so you dont see the bolts. the entire front suspension is new as well and painted,large bolt pattern. the core support was cut and modified as well.
the hood is fIbreglass with a full 6 in cowl on it,it starts at the very front of the hood where it meets the grille.
color of the car is a flip flop amethyst,at times looks dk blue,other light looks purple
the interior right now is not put together. (i just purchased 2 new racing seats).
still needing finished is the interior (in which i planned on doing in tweed), some of the windows put back in,finish wiring ,the dash has everything removed,only using the necessities,the trunk i planned on making a trunk kit in tweed as well, .
the body is beautiful,,the pictures dont do it justice. i am open to any reasonable offer. i have 25k into it. i would say its about 97%complete.
for any info, you can email me at dodge340dart@hotmail.com
