66 dodge monaco
tony nelson
New member
:bravo: hi i have a 66 dodge monaco 440 sw dual ac have cooling problem in 90+ weather 4 core hd rad hi volume w pump fan clutch new no leaks any suggestions would be appreciated
Welcome! I am with DCF, check the thermostat, assuming it is a problem that has just arisen. Is this a new setup, or was it okay before?
We need pics of your car man!
OrphanedV8s said:
Wishful thinking?:jagoff: [smilie=i: [smilie=d:[/quote]
Well, that's where I usually find him... crwled up in a ball and chanting something like," Davey.... No. Davey.... No. Davey.... No."
I'm not sure what that's all about. Do you?
[smilie=2:[smilie=f:[smilie=g:
XLR8R said:
K, back to serious, ladies!
Serious?
Are you serious?
Wow. I don't know how to deal with this request...
Should I ban you? Yeah. Maybe that's for the best. Someone or something has obviously taken over your body - or at least your computer.
:D
We didn't scare Tony away, did we? It's all just fun, Tony. And we only mean it when we're talking about beep..
Have you tried substitiuting a 3 core aluminium rad? I once ran a four core rad that gave me issues until an old racer pointed out that on a four core the inner cores actually help heat each other instead of cooling. I went to a three core with elliptical channels and never had an issue again. Just a thought.
high volume pump, 4 cores.... me thinks it just doesn't have time to do it's job.
When it approaches hot, shut it off for a minute and check the fan clutch.
Serious?
Are you serious?
Probably the computer---nothing would crawl into his body[smilie=g:
