LAWFISH
"A MOPAR FOR EVERY MOOD"
Hey gang maybe you guys can help me plan this little trucks running gear and build up. I dont know straight axels at all and am no great mechanic but have cuda, rrs, ect. New to the trucks
I have this little 63 shortbox sweptline that I want to put a 500 stroker into and slamm it down.
The front end is the original straight axle and suspension. However the font support and cross member were cut by one of the previous owners who raced the truck with a 383 in it.
I want to make it a driver 440 block/500 stroker. Who makes the entire motor mounts for the conversion to do it the right way.
Or is there a way to go with a more moderd front suspention for this application and will that even effect my motor mounts, IE mustang two style front suspension or other? or maybe a later mod dodge truck swap out???
I still dont know if I am going auto and use the shifter on the dash, which is the cable style from a 65 year truck that was swapped out and is just sitting onthe dash or maybe even a 4 speed.
If I go with a 4 speed, will a cuda, E B body 4 speed work? I dont mind moving the shifter location of there a good strong truck 4 speed that will work for this application? any suggestions??? I have several B and E body 4 speeds siting here??
Any suggestions are appreciated as I am just starting to plan the job.
Also, any one like the hood scoop I have sitting on the hood?
LAWFISH
63 dodge truck shifter
63 truck w hoodscoop pics
LAWFISH
