6.5 hrs-------354 m
jodaddy1
O.D.in' on XL's meds while
miles later. was it worth it ????? You tell me........Jodaddy's buys and traveling trip today. Lima Ohio to North of Ann Arbor Michigan (New Hudson) then to Kenton Ohio and back to Lima..........My legs are tired:doh: :D
Psst! It goes tuther way round...
attachment.php
:D
That's pretty good stuff there.
69.5CUDA said:
soo going to swap the roof out are we?? or just the back section?....i take it your rails are shot?
Well the one side is half bad and the other side is ok?? so got extras:toot: :toot: :bwuhaha:
As to the roof--- Both sail panels, dutchman panel, upper rear window track, rear deck, trunk edge lip and windshield area about 10". :toot: So to buy those panels...............over $500 I got this for............................................... well alot less:giggedy: :toot: :giggedy:
so you going to just swap the roof outright?...if so ill go snap a few pic's of what i did for a-bodys to make the job about 99% imposible to screwup...by the sounds of how much you need it sounds like a roof swap is in order
Haven't decided if full roof or grafting will be done but any ideas are welcome:dance: :dance: :dance:
that domelight powered up on the trip home would've been classic. Looks like a good score and will keep u out of trouble for awhile.
DCF your keen powers of observation do not go unnoticed :bwuhaha:
ill shoot a few pic's today but explain now...
get a small pile of that tube steel you used on the nose..remove windshield and make a extreamly snug template of the windshield area out of the square tube...this way the tube frame will not only give you something to mark where you have cut the original roof but you can then move the template to the replacement roof and copy your mark in a spot close to the original or in the exact spot...i prefer to make several cuts and slowly bring it to perfection...once both are cut the template not only helps you clamp and align the pilars but will NOT allow you to have the roof to short..it will also show you if the roof is to high and built right it will actualy square up the entire front section of the roof.......when i did the 69 fastabck for a friend useing a 67 roof..i made a template of the windshield rear window and 2 semi door templates that clamped in at the strikers door sil, front pillar, and roof line area of the door.....with the door template and front and rear templates it was next to imposible to not get the roof square...i thought all of this up from scratch after the body shop that did his roof had his
1/4- 1/2 up on the front drivers side
1/4- 1/2 down on the front passenger side
1/4-1/2 up on the passenger rear
1/4-1/2 down on the driver rear
needless to say i got me first attempt at a roof swap due to incompitant body shop...few years later and i cant even find my welds on the car
