I've been searching on this ever since the car came back without the rods installed. Surprisingly there's not a lot of info. Probably because why would you take them out?
I made a version of this with 3/4" square tube that seems like it's going to work. Battery dead so no photos.
Mine doesn't have the curved part on it but I don't think it actually needs it either. My welding is pretty miserable though. Better said, my eyesight is pretty miserable. I can burn in a perfect bead in the wrong place 9 times out of 10.
I need to be inside the trunk to use it so that's on hold for a few.
12" long, 3/4 square tube. I wish it was longer, but that's what I had.
The slot goes around the rod, then you rotate it around and the cross bar picks up the end of the bar so it can be wound to where it needs to be.
FWIW I was able to get the rods in the first slot by hand. It won't hold the trunk up there so I've gotta go tighter.
Also, if you put the little square plastic things on the end of the rod, and then the rod pops out while you've got it wound up, that plastic thing will absolutely disappear. So now I'm short one of those
With the rod in the first hole and positioned so it doesn't just pop out, the other end hits the hinge. I don't know what that was about, but it was dinner time so it can wait.
When the trunk comes down, the rod moves back, and runs right into that piece that meets the wheel well.
I'm not sure what's going on. At one point I had to move it over that direction to get the rod to latch in on the other end. I'm still messing with it. It can't be anything that complicated.
Well, I've got one in hole 2, the other in hole 1, and the hood stays open by itself now but it won't close because the rods still hit the hinge bracket.
There were pieces that filled in between the bottom of the hinge and the wheel well. Not the original ones, but some I got with a mini tub kit. These were similar but different than what was original, to allow for the 3" extra tub width. They aren't installed. Instead they pushed the hinge over to the tub for welding, and right in the way of the spring.
Right now my plan is to take about half the stick out off the end of the spring with a grinder.
It's no consolation but I pried the socket out of the parking lamp housing and I still can't get the bulb to go in.
I don't know if I'm going to be able to hack anything worthwhile together or not. The trick's going to be getting the socket in the housing and grounded. If it wasn't for that I could just RTV any old socket in there.
I might end up having to do that anyway, and soldering a ground to the sockets.
I picked up a couple of Dorman sockets and a tube of RTV. They have the grabby things on them that are always too loose or too tight and of course they are. A perfect solution would be to figure out a way to crimp them flat to where they hold the socket tight to the housing. I've got the RTV if that doesn't work.
I will probably go ahead and solder a ground wire to both of them before I go too far with this idea because I don't expect to have a good ground through the housing.
Once it's in, I used a pair of long needle nose pliers and just bent those prongs back flat against the housing and I'm your uncle. I think it's actually in there tight enough to ground.
After repainting that mess, I added the ground wire whether I need it or not, and for wiring I left about a 2" extension from the new wiring and reused the whole wire from the original parts. I even made sure I had the park and turn signal sides wired correctly.
An easy old school trick to get brighter lights without switching to LED's is to paint the inside of those open bulb light fixtures with gloss bright white paint. It's more light reflective than the silver that's usually painted in them at the factory.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
