Sounds like your moving in the right direction, get that thing buttoned up the A12 will keep you busy a while!
Providing that your syncros are good condition you shouldn't get any grinding on down shifts. The only other cause could be the clutch is not fully releasing. Or your co-ordination is off.The last time I had it out I was getting kind of good at matching revs and that fixed a lot of the gear grinding downshifts - if I remember to do it.
Right-o. I didn't rebuild the trans. It's the synchros. I've got photos here somewhere but TBH I'm not the right guy to judge from that. My thinking at the time was it's not that hard to drop the trans if it grinds. Now it's how can I get around the grinding and avoid dropping the trans.Providing that your syncros are good condition you shouldn't get any grinding on down shifts. The only other cause could be the clutch is not fully releasing. Or your co-ordination is off.![]()
Sometimes a simple "band-aid" for worn syncros is thicker lube. If you're not running 80W-90, do it. You could even try to get a bottle of STP in there. But have fun squeezing it in.Now it's how can I get around the grinding and avoid dropping the trans.
I spent a couple of hours trying different variations of those tests with the cluster on the bench, based on recommendations from the internet. No dice. Everything is in order, but neither gauge works.Fuel and temp gauges - I replaced the IVR with one of the fancy digital ones from RT engineering, but that didn't help. I have tested everything, so replacing the IVR was a hail Mary.
The gauge works when you ground the wire, the voltage at the far end of the wire pulses like it should, the senders vary resistance as they should. I took the cluster out, loosened the nuts connecting the gauges to the circuit boards and retightened them. I checked continuity across the circuit board including the gauges and it all seems OK. It beats me why the gauges don't work because there's nothing else that could be failed but that's apparently not the case.
I bought a 100 Ohm pot and it seems the gauges both work as they should with the cluster on the bench.I spent a couple of hours trying different variations of those tests with the cluster on the bench, based on recommendations from the internet. No dice. Everything is in order, but neither gauge works.
Sometimes, yeah.You are better off to source used parts than new garbage.
It IS a good way to destroy the hairspring. It would depend on how high you revved and for how long.I had the back wheels off the ground and revved it in reverse. The speedo turned backward and bounced.
With my luck, now the speedo is broken.
