I called Jerry & he insists it is the stock pan & my shape is aftermarket.
He's half-right. It
is the stock pan... for a
truck. It WILL NOT FIT an E-body. Jerry's been playing with non-stock race cars too long. There aren't a lot of guys on this site who have E-bodies, but you know who does have one? Me. That rear-sump pan will not fit any A, B, C, or E-body. It would block the steering linkage. That's why your pan has the forward mid-sump. Yes, yours is aftermarket--probably Mopar Performance or Direct Connection--meaning it's just a chrome-plated
stock pan.
There are four loose oil pans in my garage. Three of them came off 340s, and one came off a 360. One's a truck pan. My 360 came out of a truck, so I know which one's the 360 pan. I also have a 7-quart pan on a 340 that came out of a stock-chassis Cuda bracket car. It's a forward mid-sump like yours, only much deeper. It's literally a deep sump welded to a stock pan.
Here, I'll show you what it takes to run a rear-sump pan in a passenger car without switching to rack-and-pinion steering, and you can share the picture with Jerry.
In this photo, the front of the car is to the right. The oil pan shown fits E-bodies as well as A- and B-bodies since the oil-pan-to-steering-linkage relationship is the same between all three. Look over toward the left. See that "white spot" peeking between the header and frame rail? That's a reflection of the camera flash off the edge of the bellhousing flange. Obviously this is a rear sump pan, as rear as possible. The front side of the sump is close to the K-member. You can see the front edge poking out below the idler arm.
Now, see that Hugh Jass hole through which the steering linkage is passing? That's a tunnel
through the oil pan for the stock steering linkage. Pray tell, where exactly is the steering linkage going to go with that black pan in your car? You'd need a similar tunnel... or to move your steering linkage elsewhere, like ahead of the K-member (rack and pinion steering).
